SteveDavisPsyD's avatar
Jul 16, 2021
Internet light is
I have internet to the modem and can bypass the router to my MacBook. The router lights are on and it is broadcasting. However, the internet light is red/amber and flashing or is on continuously. I have used different ethernet cables to see if my cable had gone bad, but nothing changes. Some other things:
1. I cannot access the router via routerlogin.net.
2. I have powered it down and reset it.
I don't know what else to do.
Open to any suggestions.
Thanks,
Steve
  • SteveDavisPsyD's avatar
    SteveDavisPsyD
    Jul 16, 2021
    Remembered to use the Netgear Nighthawk app and apparently needed to reconfigure the router. Everything is working fine.
  • > I have internet to the modem and can bypass the router to my MacBook.
       What, exactly, is your (unspecified) "the modem"?  What, exactly, is
    connected to what, exactly?  (Hint: If a device has different types of
    ports, then "connected to device" is not enough detail.)  Is more than
    one device connected to your (unspecified) "the modem"?
       History?  Is this a new installation, or some kind of change to a
    previously working installation, or what?
    > [...] The router lights are on and it is broadcasting. [...]
       Which "The router lights"?  "on"?  Color?  Activity?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    LED descriptions and "Troubleshoot".  Further reading might not hurt,
    either.
    > [...] the internet light is red/amber and flashing or is on
    > continuously. [...]
       "internet"?  Not Power?
       "access" from what?  Connected how?  Does the computer/device where
    you're doing this get a valid IP address?
       "cannot" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
       "reset it" how, exactly?  Look for "Reset" in the User Manual.  What,
    exactly, happened when you did whatever you did?
       I don't know what you've done so far.
      The modem is a Motorolla Surfboard SB6141 cable modem
      This has been my WIFI setup for several years. My provider recently changed from Northland to Vye Broadband but it was never a problem. Talking to the provider lately, there was an outage due to a software glitch on their side. That has been resolved.
      The following lights are white: power, 2.4 GHz, 5 GHz, and the two lights at the far right... WPS and broadcast button
      The internet light is the only red one.
      either.
      Already did this and didn't find anything helpful that I hadn't already tried. That is why I came here.
      > continuously. [...]
      There is power
      I cannot log into the the router menu.
      When I tried to log into the router settings, it says that i am not connected to the internet.
      I pushed the reset button the back of the router. The only thing that happed was that it appeared to power down and restart -- no change.
        SteveDavisPsyD
        Guide
