leejkennedy
Jan 23, 2021Aspirant
IPV6 settings for BT + R8000
Hi trying to set up this router with BT in UK. they've provided the following settings, but i do not have an option for PPPoA (or PPPoATM) on my router. using firmware V1.0.4.66_10.1.75. BT's...
DarrenM
Jan 29, 2021Sr. NETGEAR Moderator
You may want to check out this KB.
DarrenM
- leejkennedyJan 31, 2021Aspirant
thanks everyone. nothing ive done from all the threads ive read here and elsewhere seems to resolve this. because im not using the homehub (i'm using their openreach modem + this router) BT are being less than helpful, with their links just providing generic info about ipv6.
the LAN is allocating addresses based on ipv6 , the WAN says ipv6 unavailable no matter what setting i change. think i'll give up and try again in a few months ;) thanks again
- michaelkenwardJan 31, 2021Guru - Experienced User
Netgear does not support BT's implementation of IPv6. At least, not in DSL:
Re: IPV6 with BT Infinity - NETGEAR Communities IPV6 with BT Infinity - NETGEAR
Communities IPV6 D7000 not working properly - NETGEAR Communities
D7000 Nighthawk no IPV6 support with BT Infinity? - NETGEAR Communities
DarrenM also noticed your subject header and provided his link.
In my case, I just let the router's wizard set up the connection. It worked as expected. But I am on DSL.
I'm not familiar with the openreach modem. There are lots of things that could fill the bill
there. As BT says:
There are five different types of Openreach modem.Is this it?
Openreach modem (ONT) explained: Ports and models available | BT Help
Have you asked for help in the BT community? Or is it one of the other four?
Welcome to BT’s official support community.
