mzguy's avatar
mzguy
Apprentice
Dec 16, 2016
Is Beta Firmware 1.0.7.6 stable and bug-free?
I have an R7000. I know the firmware is in beta. Can anyone chime in with their experiences? Known bugs? Stability? Lost functionality? Cases of successful installation vs. bricking the router?
Can a Netgear representative suggest their level of confidence with this beta, since it apparently was rushed?
Thanks!
  • I updated my firmware yesterday to the BETA version.  It has the same numbers as the "production" version.  Are they the same?  Do I need to redownload and install the production firmware?
    Thanks!
    • IrvSp's avatar
      IrvSp
      Master
      They APPEAR to be the same, size at least. Didn't bother to try and binary compared them, just installed it. Works fine after the re-boot it does when installing.
      • eurosteve's avatar
        eurosteve
        I'm thinking that the firmware didn't change just because they changed the label from BETA to Production, as long as the firmware number stayed the same.  I think they would have changed the number if they did anything to change the firmware as a result of it's trial in Beta.  Does this sound right?
