eric_bor
Jan 22, 2016Tutor
Is it possible to forward more than one port to a single port? (Or, how can I do this?)
Hi everyone, I have a service running on a port (let's say 9999). I can forward 9999 external to 9999 internal. But, what I would like to do is to forward anything that comes in on 80 or 9999 (...
eric_bor
Jan 24, 2016Tutor
Hi James,
Close. The problem I'm trying to overcome is that I am able to access the port for this service when on my internal network or via Internet. But, at work, behind vpn, I cannot use that port, so I would like to allow *either* port 80 or port 9999 to go to port 9999. So, via port 80, go to 9999. Via port 9999, go to 9999 as well.
Thanks!
Thanks!
- JamesGLJan 26, 2016NETGEAR Employee Retired
Hi eric_bor,
Please try to downgrade the router's firmware to v1.0.4.30 and check if you will get the same error message.
