eric_bor
Jan 22, 2016Tutor
Is it possible to forward more than one port to a single port? (Or, how can I do this?)
Hi everyone, I have a service running on a port (let's say 9999). I can forward 9999 external to 9999 internal. But, what I would like to do is to forward anything that comes in on 80 or 9999 (...
eric_bor
Jan 24, 2016Tutor
Hi James,
Close. The problem I'm trying to overcome is that I am able to access the port for this service when on my internal network or via Internet. But, at work, behind vpn, I cannot use that port, so I would like to allow *either* port 80 or port 9999 to go to port 9999. So, via port 80, go to 9999. Via port 9999, go to 9999 as well.
Thanks!
Thanks!
JamesGL
Jan 26, 2016NETGEAR Employee Retired
Hi eric_bor,
Please try to downgrade the router's firmware to v1.0.4.30 and check if you will get the same error message.
