Retired_Member
Jul 22, 2016Is the R7000 good enough for 200/12, possibly more?
Hi, So we're getting 200Mbs down and 12Mbs up from Virgin Media soon and are going to put the Super Hub into modem mode and connect our own router. Wireless isnt very imporant but we still want i...
- Jul 22, 2016
I have right now 200/20 (telenet cable in Belgium). The R7000 is giving me full speed on my Xperia Z2 tablet, over 5GHz, at least according to speedtest.net, so I'd say you'll be well served with it with your current connection. On the tests that I did with iperf I managed to get close to the theoretical speeds on 2.4GHz and 5GHz, so it should also handle your future speeds. Of course, it will depend on the size of your house, wall materials, neighbouring WiFi, etc.
As for the firmware, I was running the v1.0.6.28 beta for some time, and am now on the 1.0.6.54. If you don't have any arlo cameras, I'd recommend you to stay with 1.0.5 for now, as you won't gain much with the beta.
aalexandrebeta
Jul 25, 2016Master
So go for it! Give it a shot!
Retired_Member
Jul 26, 2016I see the R7800 is only £10 more than the R7000 on Amazon yet is far Superior
R7000 = £140
R7800 = £150
- aalexandrebetaJul 26, 2016Master
So go for the R7800!!!
Enjoy!
