Steinmeg
Apr 19, 2022Star
Issue serving ip address
So not sure if others have seen this but seems once a week I need to reboot the router to get it to serve IPs on the 2.4ghz band. Checked for update, router good on updates. Any ideas, I think I had to reboot my Google wifi this replaced maybe 2 times in 3 years, this fella has been rebooted at least 20 times in the last month. Been less since I added static IPS for some iot devices. Firmware is 1.0.0.58 got a 1ghz up/ 1ghz down connection....
If you truly have the xr700 from your signature, you're not on the latest firmware.
The latest is 1.0.1.48
You might try updating and then factory resetting.
- Xr1000 is on the box but some more looking at it on other websites, the model is AX5400, interesting in its own the 2 numbers....
XR1000 is the model. AX5400 is the speed.
What modem is it connected to?
there's a newer 1.0.0.64 version of the firmware.
Again, try updating and doing a factory reset/reinstall.
https://www.netgear.com/support/product/xr1000.aspx
