Anam's avatar
Anam
Issue With Mac Filtering
Hello, I just got the X10 and was settying up Mac Filtering on it and found an Issue/Bug with it, after add  couple MAc addresses to allowed list and hit apply it comes back with a grey page and doe...
  • ElaineM's avatar
    Mar 03, 2017
    Welcome to the community, Anam
    Try to reinstall the firmware and see if you will experience the same problem.
    After reinstalling, do not forget to factory reset the router then reconfigure it.
