r9000
25 TopicsWhat Netgear product will best extend my R9000 router?
I have a 6 year old Nighthawk X10-AD7200 that I have used with two old Apple access points that creates a single named cloud for my home. They are wired to the Nighthawk. I want to replace them with something using modern protocols. Does the R9000 support any Netgear mesh satellites? What would be good companion devices to do this modernization? TIASolved165Views0likes7CommentsMy R9000 is on 1.05.42 and won't find an update but I found here 1.06.46
My R9000 is on 1.05.42 and won't find an update but I found here 1.06.46. I have downloaded it. Should I install it? Router still works great except for an occasional unexpected reboot. 1x or 2x a week. Thanks!614Views0likes7CommentsThe radio of 5Ghz and 2.4 Ghz don't turn on
Hi Everyone, I have somewhat exactly the same issue. The radio of 5Ghz and 2.4 Ghz don't turn on. I already tried the 30/30/30 reset (I think all 3 methods) Changing the firmware to the Voxel firmware (many versions actually) I tried changing the Firmware to the official one in many versions 1.0.1.18, 1.0.1.36 1.0.4.84 1.0.6.46 and nothing worked. I reset the nvram using telnet as specified in other threads with the same issues. Nothing seems to be working... The 60Ghz radio seems to be working fine, since it turns on and off when I activate/deactivate it from the setup page. So.. my question would it be. Is there any way to know if the 2.4/5 Ghz radios are working or not? I have access to all functionalities of the router (admin page/ssh/telnet) Any help?518Views0likes2CommentsR9000 2.4Ghz & 5Ghz stop working
I had bought this device in January and preconfigured it before we shipped it to a Missionary House in Honduras. The Wifi 2.5 and 5Ghz stopped working and their leds are off. The firmware was updated from V1.0.2.40 to V1.0.6.46 and now to wifi connectivity. The hardware RJ45 network ports in the back all work. Any ideas on how to resolve this issue. I am not having good assistance with their technical support team.In my case on my R9000 I just got it the email last week
Great question, and already stated they do not provide that information. A more important comment to all of us is that Netgear end of life is really way before they provide the email trying to get you to buy another one of their routers. In my case on my R9000 I just got it the email last week. I was curious so I looked to see when last software update was provided and fell off my chair laughing. 1.0.5.42 was released in 2022. So they really don't care about any security issues over the last 3 years. I purchased mine in 2020 and had lots of issues with updates in the first 2 years. Not sure yet if I am going to buy a different brand next time.423Views0likes3CommentsR9000 dropping connections
R9000 is dropping connections every few min. I replaced the modem because the cable company said it was to slow. Replaced with net gear so I thought it would be compatible to r9000. Other than rebooting I am not sure what else to try. Any suggestions are appreciated.300Views0likes2CommentsX10 question, 2.5Gbit solutions etc..
Hi all, I bought a Nighthawk X10 a while back for $10 at thrift. Love this thing, but I'm now faced with a forced upgrade from my ISP (no complaints, it's the same price). My issue: the X10's ports are 1Gbit and won't be able to utilize the 1200Mbit upgrade, however, there IS the matter of that 10Gbit SFP+ port.. I know what it is, but not sure if the X10 allows it to be used for anything other than a NAS. Here's my situation though: Xfinity, going from 800Mbps to 1200Mbps. I'm in the market for a new modem, quite possibly a CM3000 (for below cost due to built up rewards) or a Motorola B12. Both modems are supported, both handle up to 2.5Gbps. My question is, do I stay with the x10 and buy a switch that has an SFP+ port and divides the load into four 2.5Gbps ports (allowing me to utilize my 1200Mbps subscription), or buy an RS100 router for $150, or, try to connect my PC directly to the SFP+ port on the X10 using a dedicated NIC that has an SFP+ port? Off topic, I know there's some firmware updates by voxal, I haven't looked into those yet. What do they offer by comparison to the EOL firmware from NG?Solved427Views0likes8CommentsUPNP no longer works
I just updated to Firmware V1.0.3.16 After the router completed the update, UPNP no longer works. I have tried rebooting the router several times but the port is not being automatically forwarded to the computer on the network. I have never had an issue with this before. Two ports that are usually handled are transmission and Plex. I manually forwarded the ports and it is working. But I shouldnt have to manually manage the connections. Any ideas on how to get it working again?Solved5.1KViews0likes7CommentsR9000 unable to see and manage in my ReadyCLOUD web page.
Hello. I own an R7000, an R8500 and an R9000. The R7000 now uses it as a wifi bridge in my home network, but a few years ago it was my router with which I registered in MyNetgear and ReadyCLOUD. I had no problem to remotely access via ReadyCLOUD either to the USB stick inserted in the R7000 or to the nas RN104 of my network. Then I bought and installed the R8500 instead of the R7000 and even then I never had any problems with ReadyCLOUD. The problems started when I bought the R9000 and installed it instead of the R8500. Through ReadyCLOUD I can see and manage the RN104 nas but I can not see the R9000 router. I went from within the router setup page to cancel the subscription to ReadyCLOUD and repeat it but without success. I have always updated the firmware of the R9000 like that of the nas RN104 and of the R7000 bridge. What can I do to get back to seeing my router from ReadyCLOUD?Solved3.4KViews0likes9Comments
