atsushi
Aug 10, 2022Follower
Just bought a new router (netgear nighthawk)
I recently bought a new Netgear Nighthawk AC1750 that I wanted to use, since it lets me mess with many more settings than the Xfinity Modem/Router combo does. The xfinity documentation said to put th...
Aug 10, 2022Guru - Experienced User
What model router do you have? R####?
After putting the ISP modem into bridge mode, did you power OFF the modem and NG router for 1 minute then back on with the modem first then the router?
Turn off and unplug modem.
Turn on computers and rest of network.
What CAT# lan cable are you using between the modem and router? CAT6 is recommended.
Contact the ISP for additional help and information regarding there modem.
