gifiduxa
Oct 21, 2021Follower
Keep the orbi or go with ax8?
I am torn between the following:
I have the 3 pack orbi ac3000 (not the new wifi 6 or newer series, the first one that came out with 2 satellites and router).
I recently acquired the net gear ax8, ax1800, nighthawk ac1900, and a few ubiquiti ac access points, and a NETGEAR EX8000100NAS Nighthawk X6S extender (I really want to sell), wondering if I could mesh up things like orbi?
Which is better?
Smoother and easier to use/setup/manage? Probably the orbi as its designed to be a mesh and have a router controlling it.
You could probably coble together a different setup with the other devices but its not going to have as seamless roamiing and you'll have to manage each device on their own.
The older I get, the more I'm inclined to use devices that just work and I don't have to mess with 5 different things to get it functioning properly. Or that require a ton of messing with to troubleshoot.
If you've already got the device, you can always try out both setups and see what works best for you.
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6and visit the Orbi forum as well if you need too:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
Which is better?
