HSP
Dec 06, 2017Aspirant
Large difference between WiFi speed and direct link speed
I have a tested speed of 350 mbps when I connect directly to the modem. That speed drops to less than 25 mbps over wifi on multiple devices. What do I need to do to improve the wifi speed?
- Is your WMM enabled? I had very slow internet speeds for awhile likely a result of firmware update in June but didn't really pay attention to it until recently. I spent last night troubleshooting it (including downgrading firmwares). I finally saved my config, reset the router and I was getting full speed. I loaded my config again and back to 20 Mbps. I reset the modem and started from scratch fiddling with different settings. I finally determined it was the WMM. The moment I enabled it went back to full speed. With one of the firmware updates it seems that WMM is required to attain full speed over wireless.
- JamesGLNETGEAR Employee RetiredHi HSP,
 What is the firmware version of the router?What is the speed when wired to the router? - HSPAspirantHello JamesGL, I presently have Firmware Version 1.0.9.12. My direct internet speed is 350 Mbps (measured today) My WIFI internet speed is 19 Mbps (measured today) Thanks,
- HSPAspirantHello, again, I just upgraded to the latest version of Firmware 1.0.9.14 My direct speed remains 350 Mbps My WIFI is now 28 Mbps Still significantly slower than direct
