TechByter's avatar
TechByter
Latest firmware breaks NAS setup
Previously I created this topic:
https://community.netgear.com/t5/Using-your-ReadyNAS/Will-the-latest-security-firmware-update-create-a-problem-with/td-p/1578063
Nobody responded, so I tried installing the new firware update and the NAS drive once again became unavailable. It seems that I am not permitted to update the topic I created, so I've started another topic to answer the previous post.
NAS drive is dead with firmware update
So I rolled back to version 1.0.3.67_165 and the drive is once again operational.
Why is it not possible for Netgear to create a firmware version that works with what would seem to be a very standard Seagate 2TB USB3 drive?
  • Thanks, Blanca.  That beta BIOS version was provided by support shortly after I bought the router because it wouldn't work with the Seagate 2TB hard drive and it was unclear where the fault was. Because of the VPNFilter threat, I have upgraded the router to a Netgear X10 and I found that it also does not work with the Seagate drive. Thus the fault was Seagate's. I've replaced the 2TB drive with a 4TB Western Digital drive and it performs properly, so the problem is solved.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi TechByter,
    I have sent you a message. Please check your inbox.
    Blanca
    Community Team
    • TechByter's avatar
      TechByter
      • Blanca_O's avatar
        Blanca_O
        Hi TechByter,
        Thank you for your feedback.  Glad that it's working now.
        Blanca
        Community Team
