Brhunt's avatar
Brhunt
Follower
Dec 25, 2019
Local offline network
I am  using my old r6700 to connect to IP security cameras but do not want to connect to internet.  Seems to work OK
BUT .. the nework time and date is wrong (by months!)
Since there is no internet connection, there is no access to an NTP server.
Is thare a manual way to set time and date?
Windows 10
  • > Is thare a manual way to set time and date?
       I know of none in the usual management web site.
       One possibility might be to gain shell access to the R6700 using
    Telnet, and use the "date" command.  Some router models/firmware
    versions have some kind of "debug" page ("debug.htm", or similar) which
    allows the user to enable Telnet access.  For ones which lack such a
    feature, a Web search for terms like:
          Netgear  Telnet  enable
    should find some programs which might help.  (I use the program which I
    modified: http://antinode.info/nte/ )
       Another possibility, if your R6700 firmware lets you specify the NTP
    server (ADVANCED > Administration > NTP Setting?), would be to run a
    time server on some system on your LAN (over which you have better
    control).
       I know nothing, but the R6700 might expect to see the NTP server on
    its WAN/Internet side, in which case, you'd need to have that time
    server system connected there.  An existing computer with a second
    Ethernet port might work, or something like a Raspberry Pi (with a real
    Ethernet port) could be dedicated to that job.
       How hard are you willing to work to get the date+time right on that
    thing?
1 Reply
    control).
    thing?
