markgrant
May 25, 2018Aspirant
Local wifi network won't appear
Plugged in new router (Netgear Nighthawk AC1750 / model R6700v2) and hooked up to existing Arris DG1670 cable modem. Local wifi network disappeared, not found. Plugged/unplugged, rebooted.
Using 2010 MacBook Pro laptop. Is it too old to work with this router? Is the Arris modem too old or not compatible?
OSX 10.13.4
Manual automaticlly assumes I can connect to my network. I can't. Returning this. I always have problems with Netgear products. Will avoid completely from now on.
> Plugged in new router [...]
Does that mean that you touched it?
https://community.netgear.com/t5/x/x/m-p/1530473
Did you configure the wireless network parameters on the new R6700v2?
No and no, respectively.- markgrantAspirant
LEDS are on and white.
Can this be done without connecting to Internet? (Using my old router now.) Because that's the problem.
Sure. There'd be a serious chicken-and-egg problem otherwise. To
configure your router, you need to connect to your router, not to the
outside world.
Step one: Visit http://netgear.com/support , put in your model
number, and look for Documentation. Get the User Manual. Read. You
might be amazed at the benefits.
