EdwardX
Mar 06, 2017Aspirant
login problem
Hi , i recently bought a night hawk however i can not login into the router, tried www.routerlogin.net/com, and by mentioned IP adress but no results. please advice, i have read Q&A but this was not ...
- Mar 08, 2017
thank your for your help, however suggestions did not work,also the genie app is not able to connect i have decided to bring my router back to the shop and aks for refunding.
Mar 07, 2017Guru - Experienced User
Other options are to try
michaelkenward
And check that this does not apply to you:
Unable to access router management page with Kaspersky installed | Answer | NETGEAR Support
