Turtletamer20
May 02, 2022Aspirant
Logon Timed out for new setup
I am setting up a Nighthawk router model R6700AX and I've gone through the setup steps on the Nighthawk app through firmware updates. Once the firmware is updated I get "Logon timed out, please try a...
- May 03, 2022
Why is the local IP address for your ethernet adapter 4 192.168.56.1? I would disable this adapter to be sure Windows is using the primary adapter connected to the router.
Might give this a go to see if you can get FW re-loaded fully and clear the routers condition:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=R9DLrLQrpaw
Try nmrpflash if TFTP doesn't work:
https://github.com/jclehner/nmrpflash
May 02, 2022Guru - Experienced User
Try setting up the router with a ethernet connected PC or laptop and web browser.
- Turtletamer20May 02, 2022AspirantThe gateway IP and routerlogin.net both refuse connection
- Turtletamer20May 02, 2022AspirantIn addition, when I do a hard factory reset (the 30 seconds on, turn off, 30 more seconds) the power light is flashing red.
- FURRYe38May 02, 2022Guru - Experienced User
30 30 30 is not necessary. Press the reset button for 10 seconds then release. I would disconnect the Routers WAN port from the ISP modem as well.
Try to access the routers web page and setup wizard should begin at 192.168.1.1 here.
