LassoTool
Mar 18, 2023Aspirant
Logs incomplete
Model: R6700v2
It seems each individual log entry is cut off, resulting in an incomplete set of data.
Example of incomplete data line:
“[Access Control] Device IMAC with MAC address xx:xx:xx:xx:xx:xx is allowed to access t Saturday, March 18,2023 22:05:12”
Focus of the above example being,
“is allowed to access t”
All of the other logs also appear to be truncated around the same place. More examples of where it cuts off:
“is allowed to acc”
“is allowed to”
“is allowed to access”
My complete guess is that if the log wasn’t cut, it would give a web address. Is that correct? What other data is missing if any? Is there any way for me to see web address visits with my current hardware?
“is allowed to acc”
“is allowed to”
The access control is limited to allow (or deny) the access from a device (by the MAC address). As most web traffic is encrypted (https), it can't show a web site URL anyway.
- KitsapMaster
In your router configuration, you can go to Advanced -> Security -> Email and set up to allow you router to send you an e-mail. Then in the Advanced -> Administration -> Logs section you have the option to Send Log to yourself via e-mail. The information and lines may be more complete than what you are seeing on the screen.
Another option is to select all of the text in the log window, copy it to the clipboard, and then paste it into a blank page in a word processing program.
- LassoToolAspirantThanks for the suggestion, I had this same thought. Unfortunately, the emailed log is sent more or less as plaintext and does not show any additional information. Everything is truncated same as before.
If you wanna set up email logging, you can follow this:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Enable-Email-Logging-and-Router-Reboots/m-p/2231485/highlight/true#M34055Though directed at Orbi, same works for NH routers too.
