axltl23's avatar
axltl23
Tutor
May 30, 2023
Looking Into Buying a New Router
I have a problem with my 5g wifi going out every day and I can't seem to fix it even with the help of people from the community. So I'm looking for a new router to buy in the 100$-200$ range that has good reliability and wont go out at all.
Please feel free to reply if you have any recommendations!
(also not sure if it is a problem with the modem or provider. My provider is Spectrum and im using their own router that they gave me called the hitron docsis pc20.)
1 Reply
  • FURRYe38's avatar
    I've found some good used/referbed routers on Amazon for cheap that work well.
    R8000, MK63 MESH. XR1000. All under $200
    Might look at a RAX50 series for newer generation class router.
