Jinmzhao
Oct 09, 2021Follower
M4300 Bootup Failure
My M4300 8x8F can't boot up, and the power LED is solid yellow. the fan works fine and rear panel has green led with PSU.
here is the informaiton from console. but i can't type anything to this window.
044 --------------++++++-+++-+++++---+++++++-++++----------------------------- ------------------------
045 ---------------++++++++++++++++++++++++++--------------------------------- ------------------------
046 ----------------+-+++++++-++-+++++++-------------------------------------- ------------------------
047 ----------------+++++++-+++++++------------------------------------------- ------------------------
048 ----------------++++-++--------------------------------------------------- ------------------------
***** Interface.......: 0
**** VDL step size...: 7.911 ps
**** UI size.........: 79.000 steps
**** Shmoo type......: RD_EXTENDED
*** UI shift........: Off or N/A
*** Calib mode......: 2D Byte-wise
*** Plot mode.......: 2D Byte-wise
** Byte............: 003
* Center X........: 043
* Center Y........: 032
00000000000000000000000000000000000000000000000000000000000000000000000000 000000 00000000000000000
00000000001111111111222222222233333333334444444444555555555566666666667777 777777 88888888899999999
01234567890123456789012345678901234567890123456789012345678901234567890123 456789 12345678901234567
016 -------------------------------------------------------------------------- ------------------------
017 -------------------------------------------------------------------------- ------------------------
018 -------------------------------------------------------------------------- ------------------------
019 -------------------------------------------------------------------------- ------------------------
020 -------------------------------------------------------------------------- ------------------------
021 -------------------------------------------------------------------------- ------------------------
022 -------------------------------------------------------------------------- ------------------------
023 -------------------------------------------------------------------------- ------------------------
024 -------------------------------------------------------------------------- ------------------------
025 -------------------------------------------------------------------------- ------------------------
026 -------------------------------------------------------------------------- ------------------------
027 -------------------------------------------------------------------------- ------------------------
028 -------------------------------------------------------------------------- ------------------------
029 -------------------------------------------------------------------------- ------------------------
030 -------------------------------------------------------------------------- ------------------------
031 --------------------------------------------------++++++++++++++++-------- ------------------------
032 ----------------+++++++++++++-+++++++++++++X+++++++++++++--++-++++-------- ------------------------
033 -------------------------------------------------------------------------- ------------------------
034 -------------------------------------------------------------------------- ------------------------
035 -------------------------------------------------------------------------- ------------------------
036 -------------------------------------------------------------------------- ------------------------
037 -------------------------------------------------------------------------- ------------------------
038 -------------------------------------------------------------------------- ------------------------
039 -------------------------------------------------------------------------- ------------------------
040 -------------------------------------------------------------------------- ------------------------
041 -------------------------------------------------------------------------- ------------------------
042 -------------------------------------------------------------------------- ------------------------
043 -------------------------------------------------------------------------- ------------------------
044 -------------------------------------------------------------------------- ------------------------
045 -------------------------------------------------------------------------- ------------------------
046 -------------------------------------------------------------------------- ------------------------
047 -------------------------------------------------------------------------- ------------------------
048 -------------------------------------------------------------------------- ------------------------
**** VDL step size...: 7.812 ps
**** UI size.........: 80.000 steps
**** Shmoo type......: WR_EXTENDED
*** Calib mode......: 1D Byte-wise
*** Plot mode.......: 1D Bit-wise
00000000000000000000000000000000000000000000000000000000000000000000000000 0000000 000000000000000000
00000000001111111111222222222233333333334444444444555555555566666666667777 7777778 888888889999999999
01234567890123456789012345678901234567890123456789012345678901234567890123 4567890 234567890123456789
000 --------++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++++ ++++++--------------------
001 ---+++++++++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++++++- --------------------------
002 --------++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++++ +++++++-------------------
003 ---+++++++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++++ ++++----------------------
004 --------++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++++ ++++++--------------------
005 ---+++++++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++++ ++------------------------
006 -------+++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++++ +++++---------------------
007 --++++++++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++++ +-------------------------
008 ------+++++++++++++++++++++++++++++++++++++++++X++++++++++++++++++++++++++ ++++----------------------
009 --------+++++++++++++++++++++++++++++++++++++++X++++++++++++++++++++++++++ +++++++-------------------
010 ---------++++++++++++++++++++++++++++++++++++++X++++++++++++++++++++++++++ ++++++++------------------
011 ----------------+++++++++++++++++++++++++++++++X++++++++++++++++++++++++++ +++++++++++---------------
012 --------+++++++++++++++++++++++++++++++++++++++X++++++++++++++++++++++++++ +++++---------------------
013 -----------++++++++++++++++++++++++++++++++++++X++++++++++++++++++++++++++ ++++++++++----------------
014 ------------+++++++++++++++++++++++++++++++++++X++++++++++++++++++++++++++ ++++++++------------------
015 -----------------++++++++++++++++++++++++++++++X++++++++++++++++++++++++++ ++++++++++++++------------
016 -+++++++++++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++ +-------------------------
017 ---+++++++++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++ +-------------------------
018 ----------++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++ +++++++-------------------
019 --++++++++++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++ +-------------------------
020 --++++++++++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++ ++------------------------
021 --++++++++++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++ ++------------------------
022 --------++++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++ ++------------------------
023 ---+++++++++++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++++ ++------------------------
024 -------------------------------------------------------------------------- --------------------------
025 -----------------------------------------------------+++++++++++++-+++-+-- +-+-+---------------------
026 -----------------------------------------------+++-++++++++++-++----+--+-- --------------------------
027 -------------------++-++---+++++++++++++++++++++++++++++++++++++++++++++++ ++++++--------------------
028 ---------------------------------------+---------+-+--+++-++--+-+--------- --------------------------
029 ------------------+----+-----+++++++++++++++++++++++++++++++++++++++-+++-+ ---+-+--------------------
030 -----------------------------------------------++-+++++++++-+++++--++--+-- --------------------------
031 ---------------------+-+++-----++++-+++++++++++++++++++++++++-+++-+-+--+-- --------------------------
**** Shmoo type......: ADDR_EXTENDED
*** Calib mode......: 1D Word-wise
*** Plot mode.......: 1D Word-wise
00000000000000000000000000000000000000000000000000000000000000000000000000 000000 0000000000000000000111111111111111111111111111111111111111111111111111111 11111 1111111111111111111111111111111111111
00000000001111111111222222222233333333334444444444555555555566666666667777 777777 8888888889999999999000000000011111111112222222222333333333344444444445555 55555 6666666666777777777788888888889999999
01234567890123456789012345678901234567890123456789012345678901234567890123 456789 1234567890123456789012345678901234567890123456789012345678901234567890123 45678 0123456789012345678901234567890123456
000 -------------------------------------------------------------------------- -------------------------------------------------------------------------------- -------------------------------------------
**** Shmoo type......: CTRL_EXTENDED
*** Quick Shmoo.....: On
*** Plot............: Off
*** Copying.........: VDL_STEP
** From............: AD00 - AD09
** To..............: AD10 - WE_N
1 Reply
This place is for Nighthawk WiFi Routers. The M4300 isn't one of those.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Discuss Ethernet Switches Plus and Pro Managed
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
