Snamellit
Oct 02, 2016Aspirant
Mac genie installer NETGEARGenieinstall.dmg is corrupt
I tried to install the NetGear Genie software on my macs (both on my iMac and on my Macbook) but whenever I download the Genie installer it complains on 'invalid checksum'.
I tried from the download center, from the R7000 support page and ever from download.cnet.com. All same result. Other dmg files downloaded work just fine.
I used OS X El Capitan on both Macs.
Anyone else with this problem? Any known workarounds?
thanks,
Snamellit
Same here... seems to be unsigned.
From Console "Diagnostic and Usage Report":
assessment denied for NETGEARGenieInstaller.dmg com.apple.message.domain: com.apple.security.assessment.outcome2 com.apple.message.signature2: bundle:UNBUNDLED com.apple.message.signature3: NETGEARGenieInstaller.dmg com.apple.message.signature5: UNKNOWN com.apple.message.signature4: 3 com.apple.message.signature: denied:no usable signature
macOS Sierra does not allow unsigned packages anymore. You can work around it at your own risk:
http://osxdaily.com/2016/09/27/allow-apps-from-anywhere-macos-gatekeeper/
On El Capitan I think a simple right-click "Open" from the Finder is enough. Or change the permissions in the "Security & Privacy" Settings panel.
- djmuttersInitiate
Nothing to add apart from I have macs and I have the same issue :-(
- SnamellitAspirantThanks for confirming this issue. Now I know it is not some weird local issue.
- mcgreggInitiate
- SnamellitAspirantThank, I confirm that I now have installed the app. Still, someone at netgear should whip out their credit card for an Apple Developer Subscription to sign their apps.
