arthurmoore's avatar
arthurmoore
Mesh System Extending Upwards
I am very happy with my mesh system by sturggling to extend upwards to the 4 floor of my home.
I have the Mr60 with 2 satellies.
Any reccomendation for further extending this up to my 4th floor.
Thanks
  • plemans's avatar
    What is your house made of for interior walls/floors? Certain materials block wifi well.
    How big is it? 4 floors doesn't tell us much
    • arthurmoore's avatar
      arthurmoore
      Think it is a fairly standard plaster board with a normal size height (sorry I can be more specific is required)
      The signlal is absolutely great until the attic where it drops dramatically with the increased height of approx 3m. So thinking an extended added onto my mesh system would over come this.
      • plemans's avatar
        You can add more satellites as needed.
        I just caution based on materials. things like concrete, brick, plaster lathe, foil lined insulation, metal, all do great jobs of blocking wifi and if that material is in between, sometimes the adding doesn't help.
