mellishr18
May 20, 2021Aspirant
Minecraft issues - Netgear Nighthawk AC1750
I’ve been unsuccessfully trying to run a Minecraft server on my Nighthawk router since I purchased it in early February and I figured I could ask for help here. I’m experienced in running Minecraft se...
- May 20, 2021I fixed the problem. If anybody else sees this thread in the future, my issue was with Windows Defender firewall. Adding an exception for the server fixed my issue and everything is working as it should.
Thank you for being not only unhelpful, but unexpectedly rude.
antinode
May 20, 2021Guru
> [...] my Nighthawk router [...]
> Model: R6700|Nighthawk AC1750 Smart WiFi Router
R6700[v1], R6700v2, or R6700v3? Look for "Model" on the product
label. Firmware version?
> [...] I've properly forwarded port 25565 on the device that is running
> the server, [...]
It's nice that you're happy, but your satisfaction has less value
than an accurate, detailed description of what you did.
> [...] It's still not working [...]
"not working" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
For the usual problems with port forwarding, see:
https://community.netgear.com/t5/x/x/m-p/1859106
> [...] I have a modem (Arris CM3200) [...]
A simple modem. Should be harmless.
