bigw3260
Mar 29, 2017Star
Mobile devices slow on Nighthawk R7900
I noticed that all smart phone users in my household are experiencing what appears to be very slow wireless internet speeds. When an app is opened such as Instagram it takes some time for pictures an...
- Mar 30, 2017
No OS update did not forget the network settings. I had rebooted the phones as well as the router and that did nothing. My youngest son has the same phone as I do and we did tests with his phone on his wifi network which is a Xfinity router and he had none of the issues we had until he came over to my house then his would have same problem.
I think there was something that Samsung and Netgear where banging heads in the wifi and the OS update changed what ever that was.
Oh Well it is working now!! :smileyvery-happy:
So will not worry about it until Netgear comes out with new firmware and it breaks it. HA HA
michaelkenward
Mar 30, 2017Guru - Experienced User
bigw3260 wrote:I noticed that all smart phone users in my household are experiencing what appears to be very slow wireless internet speeds.
How slow? Unfortunately, "appears to be" isn't really a scientific measurement.
Remember, wifi will always be slower than wired. Nothing will do 180Mbps over wifi. That's physics. And it takes two to wifi, the client has to be up to scratch, not just the router.
There are some things you can try to squeeze more out of your wifi, like trying different bands and ensuring that your wifi devices have the latest software.
Then again, you say that "when you run the test the download speed tests fine" which means that the "pause" you see almost certainly has nothing to do with your router. It is your wifi client doing things on the Internet. You confirmed this when you said that the 4G phone does the same thing. And the laptop behaves properly. (Is it wired?)
In other words, you don't seem to have a problem.
- bigw3260Mar 30, 2017Star
Typo on my part. 4G has no delay and works flawlessly. Android smart phones where tested on another wireless network and did not have same issue. As far as the "appears" there is up to a 1 minute delay before loading starts on the apps.
- michaelkenwardMar 30, 2017Guru - Experienced User
That's a different story.The extra information does bring it back to the Netgear stuff, especially when the wifi devices behave on the road.
Have you tried messing around with wifi bands?
Is the laptop wifi?
Yes, Lap top is wifi and works fine. I have changed the channels, and tried both bands with results the same. Even tried different DNS provider with no change.
Interesting development.... My Samsung S7 just updated today to Android Nouget OS. Tests so far seem to indicate that it has resolved the problem on my phone. My other family members are not home so will have to see if they got an update as well. Crazy thing is like I said my phone did not have the issue with the older OS on any other wifi locations other than mine with the Netgear. I am wondering what was not playing nice between the Netgear an Android since new OS seems to have solved issue at least on my phone.
