YakFlyer's avatar
YakFlyer
Follower
Dec 09, 2021
Mobile Phone Hotspot - Netgear Nighthawk R7800 AC2600
Hi
Trying to use my mobile personal hotspot data using the R7800 Nighthawk, any advice would be very welcomed.
Thank you.
YakFlyer
1 Reply
  • plemans's avatar
    What mobile phone hotspot do you have?
    Have you check with the mobile provider on if the hotspot supports a direct connection?
    What error are you getting?
    Is the R7800 in AP mode or the hotspot in passthrough mode?
