sparkles_2014
Jul 27, 2016Aspirant
model ac1900 wi-fi is turned off
Up until a week ago, router was working fine; for some reason wi-fi is shut off - i contacted support and did recommendations but nothing worked. The unit was purchased in 2012 - I'm trying to decid...
- Aug 15, 2016
Purchased new router; as I said, old one no longer functions and cannot be fixed. I appreciate everyone's help, but sometimes you just can't raise the dead.
IrvSp
Jul 27, 2016Master
There is a button on the top of the router, is that pressed in? That will turn off the signal.
Use a browser and check if the wireless SSID is on. It needs to be on to see the SSID. It might be off.
- Retired_MemberJul 27, 2016
The manual states in default settings, Wireless and SSID broadcast are on , so A reset to default factory settings if done correctly should override the front button. Mine is working fine so I don't want to test it.
2nd led/button from top right is radio off on switch too. Try reading the manual!
- sparkles_2014Jul 27, 2016Aspirant
I'm sorry, I read the manual and I don't believe i've read any manual that has actually helped. I'm 72, have worked with computers since the 1980's (mainly mainframe), but a lot of this new technology escapes me. I'm not senile yet, but sometimes I think I'm getting close. Anyway, I held the button down for over a minute and nothing flashed. Please bare with me, I'm trying to figure this out. I'd appreciate you patience.
