tflott
Oct 14, 2021Aspirant
Model R8000 drops bandwidth from router
I have Spectrum as an ISP and use their provided modem. My service is 400Mbps, and when I connect directly to the modem, I get those speeds. However, when I connect my R8000 router, my speeds fluctuate between 150 and 250 Mbps.
I am using the latest firmware, and this is what I have tried:
-Disable Armor
-Disable Circle
-Disable QoS
Does anyone have any other suggestions or explanations regarding my loss of bandwidth?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? - plemansGuru - Experienced User
what actual firmware version are you on?
Are you testing wired?
Make sure that qos, access control, traffic monitoring, and parental controls are disabled and do a reboot.
If that doesn't help, do a factory reset and reinstall and leave all those disabled. they can disable ctf which can cause slow downs.
