Teenie
Jan 02, 2022Initiate
Model Rax35
To change my Wi-Fi password should I use Www.router login.net?
I have a new cell and I opened the Nighthawk icon. Prompted me to log in. I wasn’t sure which password so I reset It. This got me into the nighthawk app. Did this change my Wi-Fi password or just the app password.
I believe bitdefender is used to download on my devices for protection outside my Wi-Fi area is this correct and is this the best option for using your cell beyond the range of the Wi-Fi.
Thank you. I’m sorry that’s it’s a simple question for you all but I’m 68 and if I call Customer service I’ll have to buy a support pkg for these two dumb questions. Please help me. Thank you Eileen
You can change it through the app or using the browser. Either method works.
You can always log into the router through the browser and check what the ssid/password is.
