melmat
May 15, 2016Aspirant
Modem or ONT
Hi Team, I am wanting to purchase this but before i do i was just wondering do i have to plug the R8500 into my current Modem/Router and apply bridge mode. Or can i plug the R8500 straight into t...
- May 16, 2016
Thanks, i forgot to mention that i live in New Zealand and after some research i found out that some ISP's in New Zealand will let a router connect to the ONT only if it supports VLAN 10 tagging on the WAN port. So thats my next mission now is to find out if the R8500 has this feature.
TheEther
May 15, 2016Guru
It depends on your ISP. Some ISPs require you to use their gateway for authentication. AT&T U-Verse is one of them. If that's what you have, there are instructions for putting it into bridge mode. Let me know if you need them.
melmat
May 16, 2016Aspirant
