Unfiltered1
Oct 20, 2016Tutor
Mounting An X10 R9000
My current Netgear R7000 is mounted on a livingroom wall with the mounting holes on the bottom of the router. Can the new X10 also be mounted to a wall or does it need to sit on a shelf?
- Oct 21, 2016
Hi @Unfiltered1
Welcome to the community!
Yes, you can mount it!
ElaineM
Oct 21, 2016NETGEAR Employee Retired
Hi @Unfiltered1
- Unfiltered1Oct 21, 2016Tutor
Hello Elaine and thank you for the reply. Couldn't tell for sure from the pictures if the antennas would move into a position to allow hanging the router on the wall. This is my current setup. At the moment I'm gathering parts for a new build so it may be a while before I upgrade the router but the X10 definitely looks good.
- ElaineMOct 25, 2016NETGEAR Employee Retired
You're very welcome.
Glad you're liking the unit!
