Unfiltered1
Oct 20, 2016Tutor
Mounting An X10 R9000
My current Netgear R7000 is mounted on a livingroom wall with the mounting holes on the bottom of the router. Can the new X10 also be mounted to a wall or does it need to sit on a shelf?
- Oct 21, 2016
Hi @Unfiltered1
Welcome to the community!
Yes, you can mount it!
Unfiltered1
Oct 21, 2016Tutor
Hello Elaine and thank you for the reply. Couldn't tell for sure from the pictures if the antennas would move into a position to allow hanging the router on the wall. This is my current setup. At the moment I'm gathering parts for a new build so it may be a while before I upgrade the router but the X10 definitely looks good.
ElaineM
Oct 25, 2016NETGEAR Employee Retired
You're very welcome.
Glad you're liking the unit!
