LawshrinkMD's avatar
LawshrinkMD
Much slower LAN speed than direct from the house network
I am now connected to gigabit service, with the google fiber router feeding service into the house Cat5e wiring.  I noticed my computer speed tested at 940 or so up and down direct into the wall, but when connected to the wired lan ports on the back of the R6700, I "only" get 435 MPS down and 500MPS up.
Any ideas on how to get faster wired speed and still use the router?  I was reading other posts, and I made sure blocking was off.  Are there other things to do to get the throughput higher, or is this router just not up to the job?
Thanks!
  • Everything is working fine now, I got rid of my Google Fiber Network box, and replaced it with a Netgear Pro Smart Switch which can do the vlan2 tagging.  Anyway, the router is working fine, passing 900+ through the wired ports.
  • Make sure the following are all off.  If any are on, reboot after turning them off.
    • QoS
    • Traffic metering
    • MAC address cloning
    • MAC address access control
    • Keyword blocking
    • Service blocking
    • AP mode
    Alternatively, perform a factory reset and do a minimal config (i.e. Wi-Fi and LAN settings).  Don't turn on any fancy features.
    • LawshrinkMD's avatar
      LawshrinkMD
      Hmm, I tried that and no luck, still only reading in the 300-400 MPS.  I then changed the router to be an access point, still no luck.  Any other ideas?
      • TheEther's avatar
        TheEther
        Guru
        I forgot to mention that PPPoE will also drag down performance.
        Have you enabled any other features on the router?  ReadyShare?
