dsears's avatar
dsears
Tutor
Dec 21, 2022
My R6700v3 router drops the speed from the Modem from about 300 to 45 to 50
  • plemans's avatar
    1. what firmware are you on?
    2. what modem/gateway is it connected to?
    3. what device are you testing on?
    4. are you testing wired? wireless? over 2.4ghz? over 5ghz?
    5. what site are you testing?
    Overall, what wired speed do you get? Thats the key detail.
    • dsears's avatar
      dsears
      Tutor
      I hope the following will answer you questions:
           V1.0.4.128_10.0.104
          Spectrum Land Line direct to the modem.  Router connected Ethernet direct to the Modem
          Laptop Computer
          Both--5 foot Ethernet cable connected between laptop and router.  When cable is connected-the 300+ reading, when removed,   the 45 to 50 reading.
          I am using the Spectrum Speed Test.
          Wired (Ethernet) direct to laptop, 300+, Laptop or Desktop (not wired) on the house WiFi 40 to 50 mps.
      dsc
      • plemans's avatar
        So hardwired you get full speed.
        When over wireless you're only getting 50mbps Ish.
        But you don't say if you're connected to the 2.4ghz or the 5ghz.
        2.4ghz is a slow network and sensitive to interference so 50mbps over 2.4ghz rather solid speeds. Over 5ghz, not so much.
        What wireless card is in the laptop you're testing with?
