SRC54
Oct 10, 2025Tutor
My R9000 is on 1.05.42 and won't find an update but I found here 1.06.46
My R9000 is on 1.05.42 and won't find an update but I found here 1.06.46. I have downloaded it. Should I install it? Router still works great except for an occasional unexpected reboot. 1x or 2x ...
SRC54
Oct 16, 2025Tutor
Yep, the reboots are not a big problem and sometimes goes about 2 weeks. I hate to install it and cause more problems. But I never had to do a re-setup after an install.
Oct 16, 2025Guru - Experienced User
Sometimes it's best to factory reset and setup from scratch. Something in the router maybe mis configured or not working right. If you haven't done one in a long time, maybe over due.
What all do you have connected at the router?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How is the wifi configured?
Also you may want to give Voxels FW for the R9000 a try as well. He's been continuing to update FW for the R9000.
