bagjunah's avatar
bagjunah
Follower
Nov 27, 2021
my router won’t reconnect
powered off then back
  • FURRYe38's avatar
    Doesn't give us much to go on.
    Reconnect to?
    Can you confirm the brand and model# of your router?
  • michaelkenward's avatar
    michaelkenward
    Is the A7000 WiFi USB Adapter listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
    • wcalifas's avatar
      wcalifas
      Prodigy
      do you have cable internet? If so you have to reboot the modem and wait til it connects to your provider then you turn on the router to detect the internet.
