odbammb
Dec 15, 2021Star
Name of Wireless1 SSID Not Showing in Attached Devices SSID Column
SRR60 + 2 SRS60 V2.7.0.122
Every since the V2.7.0.122 firmware upgrade the Wireless-1 router to AP backbone SSID name does not show up in the Attached Devices screen SSID column. Also the overview shows no attached devices (count=0). But when I log on to the AP's it is showing the Wireless-1 SSID name.
What does this mean?
TY
Try a factory reset and setup from scratch after the FW update.
Netgear has set up a community forum specifically for the Orbi Pro products. Most of the people who watch that forum are more likely to have experience with Orbi Pro and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Thank you.A full factory reset was performed.
I would post a screen capture of what your seeing...
What browser are you using?
Happens in a different browser?
