PaulGorman
Mar 26, 2022Aspirant
NAT D setting for Nintendo Switch
Hi Community. We are having trouble with the NAT D setting on out nintendo switch. We have tried all sorts of IP and DNS numbers, port forwarding and checking of security settings (it allows the switch). We cannot get the NAT setting to change. Is there any advice out there please.
Advice would be a full understanding of your setup.
1. what modem/gateway do you have?
2. what router are you using?
3. what firmware is on the router?
- PaulGormanAspirant
Apologies. I am not very computer literate. Where do I find all that information? Thanks
This will tell you which Netgear device you own.
Then there is this:
Search - NETGEAR Communities – Nintendo Switch
Add your device model for finer details.
