PMoonchild
May 07, 2022Follower
NBN SOS-ROC requirements?
Back in Feb received this message from my IP:
Hello Jenny, |
On 31 March 2022, NBN Co is upgrading NBN FTTB/N services with a requirement for all modems to support a new stability feature called SOS-ROC.
Our records show that you are currently using an NBN modem that may not support SOS-ROC for your NBN service with the username jennyrock2010. |
Here’s what you need to do:
Me now: the reason I bought this router was bc iinet told it would solve my poor upload speeds and constant freezing or dripping out while attempting to work through zooming. They told me to buy this router bc they supported it, and their own router wasn’t very good. Have other people encountered this issue? Internet dropping out due to new NBN requirements? |
1 Reply
1. what router do you have?
2. your ISP changed their requirements. Netgear didn't force them to. So if you're upset at someone, its the corporation that changed their requirements to force users to upgrade. If they forced this change on you, they should be the ones supplying you with a modem/router since they're phasing yours out. Those features require certain hardware features that have to be built into the cpu on the router. If the router doesn't have those features in hardware, no amount of firmware upgrades will fix it.
