ScottMax's avatar
ScottMax
Follower
Mar 30, 2025
Need acess point added to static IP setup
I have an AC2600 setup with static IP for use with a camera system that is used for live streaming.  I have the system hard wired with cat 7 Ethernet cable from  this router to another location within the building.  I need to provide a WIFI access point by placing a second router to this setup.
What is the best way to configure the second router to pair off this hard wired network?.  I have a PoE switch at the end point and the camera, computer and the second router would be connected via the ethernet cable.
I need to reprogram since the fiber optics feed was damaged and I must reconfigure the entire network.
