mdjaskolka's avatar
mdjaskolka
Need advice upgrading from XFi
Hello,
I currently use the XFi gateway (modem) and the XFi pods.
My home was built in 1860 abd the walls are brick and also lathe/plaster.
WiFi has its issues even with the XFi pods.
I am looking to upgrade am am OK with replacing the XFi gateway was well.
However I would like suggestions on Netgear products to install a better mesh system.
The home is 3 floors (including basement) and about 3,300 sqft.
I do have Xfinity Voice service.
Should I look at something like the following...
NightHawk 10Gbps modem (CM1200) + NightHawk WiFi 6 Mesh + 3 Satellites (MK64)?
Any advice is appreciated.
Thanks
  • plemans's avatar
    You're going to have issues with all the systems because of the plaster lathe setup.
    It does a great job of blocking wifi.
    And the xfi pods are actually pretty solid which pains me to say. :)
    so If they're struggling to get a reasonable connection, your probably going to struggle with most systems.
    If you're wanting solid/reliable connections, you'd be better to invest money into finding a way to hardwire in the access points/satellites from a mesh system.
    either by having someone run ethernet, by using powerline (might be sketchy with older wiring), or using moca adapters (ethernet over coax).
    • mdjaskolka's avatar
      mdjaskolka
      Thank you for the advice.
      It's an option I had not considered and probably a fairly pricey one but one i have to keep in mind.
      Thanks again
