Mr_DJ
Nov 09, 2022Apprentice
Need help!! How do I connect a wifi access point to a r7800 wirelessly?? ;-)
Hello, good people in these forums! 😉 My task is this: Connect at recently bought outdoor, non-wifi, surveillance camera to my Netgear r7800 2,4GHz wifi network! By connecting the camera(thro...
michaelkenward
Nov 10, 2022Guru - Experienced User
My task is this: Connect at recently bought outdoor, non-wifi, surveillance camera to my Netgear r7800 2,4GHz wifi network! By connecting the camera(through ethernet cable) to a external wifi acces point! 🙂
Forgive me if I don't dive all over the Internet looking for manuals for different brands.
What you are talking about in general is using the R7800 as a router that has a wifi "bridge" to another router.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Use the Router in Bridge Mode
Now dig out the manual for your other device and look for the details on how to use that in the same way.
Be warned, not all routers offer the choice of bridge mode. So it may not be possible with your TP-Link.
There is another option that you could investigate. Powerline Ethernet lets you use your mains circuit as an Ethernet link.
Mr_DJ
Nov 10, 2022Apprentice
Hello and thank you for feedback! 🙂
Quote: "Forgive me if I don't dive all over the Internet looking for manuals for different brands..."
You don't have to, I already provided direct links in my original post to each network product(Router+access point)...to help save time, for those truly wanting to help me! 😉
I usually am the one helping others on this(and a lot of others forums), but as I stated, I currently am facing some brain issues(can't focus on what I'm reading and information gets lost in translation 😉 ), which is not very pleasant!.
I don't really have the ressources/energy for this project, but since it's a matter of emergency(mentally ill neighbour who threatens to kill and do violence), I need to setup a survelaince camera, so I can protect myself and closest neighbours...and provide evidence for the cops to take action. Hope I made myself more clear for everyone reading my thread! 🙂
If you cant help, that is okay....hope someone else who can, reads my thread then! 🙂
I already(before creating this thread) tried setting the Netgear to "bridge mode", but didnt see any helpful settings emerge. Regarding the AP, well, it only seems to have Access Point as the only selectable mode(not at big surprise, I would think? 🙂 ).
And this is where my brain shut down....as I don't have the energy to read up on all the details on what is required to make a reuter and acces point able to communicate with each other and what settings should be configured in each, in order to do this...but I figured the steps are probably few and pretty quick to perform.....once you know how to do it! 😉
- michaelkenwardNov 11, 2022Guru - Experienced User
Forgive me, you expect us to read manuals for devices that have nothing to do with Netgear, but you don't have the time to read how to get a router and access point to cooperate in bridge mode.
There is no simple way to go about this. In this case, you should probably seek help from the people who made this third party access point. My guess is that it does not support what you are trying to achieve.
