Ray65PDX's avatar
Ray65PDX
Need help in upgrade solutions
I currently have a Netgear AC1900 R-7000 router that needs replacing, (7 years old). My IPS is Ziply Fiber, and they supplied a NON Coax DSL Modem that I wish to replace with a NON coax DSL or VDSL? Modem Router combo.
 Finding a non coax Modem is about as impossible as finding an honest politician.
 Netgear states the N600 is wireless, (non coax) on the interweb, but on their site here, the N600 model is Coax.......
Any suggestions/help/hints ?
Thank you to all that replies.
Ray65PDX@gmail.com
  • plemans's avatar
    Why are you going from an AC1900 to a N600 device?
    Thats a large step backwards. (big one too)
    And why doesn't zipply provide you with an ONT so you can connect whatever router you want to it?
    Did you check with them about an ONT or gateway?
    • Ray65PDX's avatar
      Ray65PDX
      Thank you for the quick respons....
      The N600 was a reference only for the last Non coaxial Modem I saw from Netgear.
       What I want is a new Non Coaxial DSL VDSL Modem and Router combo.
       Zipply power supply to the house is Non Coax, telephone type connector to their supplied Modem.
       I wish to replace their Modem with one I own, and upgrade my old Router. A Modem and Router combo would be ideal, if I could find one with the Non Coax input.
      Bottom line, if I cant find the right type of Modem, I'll live with Zipplys and get a new Router. Not ideal for what I want to have, but that's life......
      Again, thank you for your insight and knowledge
      • Kitsap's avatar
        Kitsap
        Master
        Questions for Ziply.  Does Ziply allow end user owned modems to connect to their DSL network?  If yes, do they have a list of approved devices?  If no, it does not matter.
