TheJ-Man's avatar
TheJ-Man
Follower
Nov 09, 2022
Need Help! Nighthawk AC1900 Router (R6900P) reboots when I leave with cellphone
So my Nighthawk AC1900 Smart WiFi Router (R6900P) will disconnect from the internet/reboot whenever I leave the house or disconnect my phone from the wifi. My cellphone does contain the nighthawk app. However when other people connected to the wifi leave or disconnect. It does not reboot. I can't find it anywhere.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
  • michaelkenward's avatar
    michaelkenward
    Freaky.
    Do the logs for the R6900P show anything useful?
