Zmenasco's avatar
Zmenasco
Need help pairing Ac1000
Hello,
I have the AC1000 WiFi Router. I just recently purchased Xfinity service. The activation line was very confusing on what I needed. So here I go.
For the Ac1000 router, do I need to buy a modem to go with it? The router I have only has an ethernet cable, while the guy on the line explained to me that the connection should have a coax cable.
Xfinity never gave me a modem, do I get it from them? Or would I have to buy a modem with the coax cable and connect both the router and modem?
Thanks, any input would help.
  • plemans's avatar
    You have the R6080? its a router only device.
    Xfinity does require a cable modem to connect to them.
    You can rent one from xfinity or purchase one yourself. Up to you which route you go.
    • Zmenasco's avatar
      Zmenasco
      Thank you,
      Does netgear have a modem I can purchase?
      Or would I have to receive it directly through Xfinity?
      If I can purchase it, what modem is compatible with the Ac1000?
      • plemans's avatar
        Netgear has many modem compatible with xfinty.
        It just depends on speed and modem.
        1. AC1000 is a speed, not a router model. What router do you have?
        2. What speeds do you plan on subscribing to? Or plan on upgrading to?
        If you go to xfinity's site, they tell you what modems for each speed tier.
