MattyCakes's avatar
MattyCakes
Need help setting up time machine
Hello netgear community.  I am having a hard time setting up a time machine backup to a usb 3.0 drive (no external power) connected to my nighthawk wifi router.  I have been through countless tutorials and discussion boards. I have tried both smb and afs connections (with some people mentioning afs is the correct connection and others smb.)  I am using Mojave, 10.14.6 and as far as I know, the router has the latest firmware installed (V1.4.1.42_1.3.4).
Here's what I can do.  The drive can be mounted via readyshare->T_Drive and I am able to copy files back and forth between my mac and the usb drive (T_Drive) connected to the router.
What I can't do is set up a time machine backup as the drive is not "visible" to the time machine control panel (that is to say when I choose "select disk", the drive cannot be seen and therefore I can't set up time machine backups.)
One person suggested direct connecting to the mac and performing the first backup to the drive the normal way.  Unfortunatley the drive is still invisible to time machine.
Any help getting this set up would be greatly appreciated!
-Matt
