joerozic's avatar
joerozic
Follower
Dec 19, 2021
need power cord
  • plemans's avatar
    Netgear doesn't sell replacement power supplies/cords. But most of netgears devices use pretty generic power supplies that you can pickup from 3rd parties like amazon for pretty reasonable. You can even check in your parts bin/old device bin and see if it has a matching power supply. Just make sure it has the same voltage and polarity. It can have more amperage but don't go with something that has less or it won't run or if it does, won't be stable.
    • wcalifas's avatar
      wcalifas
      Prodigy
      you can find some on ebay or amazon, just make sure its the same voltage and polarity.
