DavidNGarcia95
Mar 29, 2021Aspirant
Need some advic with At&t fiber with R7000
Need some advice or help with a night hawk R7000. I recently got At&t fiber 1000, to me it doesnt seem like i have it set up right, or maybe i dont have the right router. I have it directly hooked up ...
DavidNGarcia95
Mar 30, 2021Aspirant
The bgw320 is connected to at&ts fiber network. I have the router hooked up from port 1 to 1( bgw to the R7000). More so was asking if there's proper way or any advice in proper installment of the R7000 to the bgw320, might be upgrading my router as well. Ive looked up the bgw320, and have 0 clue as to how to go about maxing out speed, or if i need to upgrade
antinode
Mar 30, 2021Guru
> The bgw320 is connected to at&ts fiber network. [...]
Which part of "exactly" did you find hard to understand? Is there a
cable of some kind or other which is connected from some port or other
on the BGW320? To what is the other end of that cable connected?
> [...] I have the router hooked up from port 1 to 1( bgw to the R7000).
> [...] Look for "Set Up the Router as a WiFi Access Point" in the User
> Manual.
Did you?
> [...] More so was asking if there's proper way or any advice in proper
> installment of the R7000 to the bgw320, [...]
> Manual.
Did you?
> [...] Ive looked up the bgw320, and have 0 clue as to how to go about
A Netgear forum might not be the best place to ask about optimizing
your BGW320.
- DavidNGarcia95Mar 31, 2021AspirantOh my bad, no the bgw320 is only hooked up the the router and the fiber optic cable, speed just seems slower to me. I did go over the manual, think i might have to rest to factory settings. Not sure if the password was ever changed on the router to access the router settings. Im more so am wondering if i should be upgrading the router, not the bgw. I dont even know if theres another modem that AT&T will be compatible with. Know AT&T is picky that way
