tomhandley8
Apr 04, 2021Tutor
Need to add mesh to Nighthawk X6 - recommendations?
Hello. I purchased the Nighthawk X6 to optimise the WiFi in my house and also apply controls using the Circle app. My issue is that my son has been used to plugging in an Ethernet cable with the extender that my previous WiFi system (Virgin Media) provided, and it is not compatible with the Nighthawk. I have tried a WiFi extender but the response times for his PC gaming are not good enough. So my question: how do I extend the Nighthawk WiFi such that I can get the signal to his bedroom and then have an Ethernet cable from the extender / mesh device into his PC? Is there a recommended Netgear device to connect to the Nighthawk? Thanks in advance!
Are you just adding 1 or more than 1?
If its just one, I'd recommend a triband mesh extender like the ex7700/ex8000
If you're needing more than 1, then I'd look at a full mesh system like orbi
what extender did you have?
Whats the size of the home?What are the interior walls made of?
What speeds did you get out of the extender?
- The repeater was Rockspace WiFi Repeater - 1200Mbps Dual Band WiFi Booster 5GHz and 2.4GHz, AC1200 WiFi
House walls are brick / plaster
Speeds were around 35 Mbps, which is normally ok but seemingly nowhere near as good as he was getting go the Ethernet cable plugged into the repeater in the previous set up.
I think I need a mesh set up so that I can connect a cable to the mesh device which will connect to the gaming PC. Thanks for any advice you have- plemansGuru - Experienced User
brick and plaster lathe are amazing at blocking wifi signals.
A mesh system might help but if the wireless backhaul doesn't have a good connection, its still going to struggle
- MaryESmithAspirant
Cant find details on this.. i want to add mesh to my network.. the current router works great in most places.. but looking to add mesh +ethernet to media areas like in my living room where the devices could use a boost of bandwidth for streaming services. I like the nighthawk satelites they provide an ethernet for devices that arent wifi enabled or dont support faster wifi technology.
Can I "mesh" satelite boxes directly with my ac3000 or do i have to use the router?... I know i can just plug the "internet" port into my routers network but that sort of defeats the purpose doesnt it?.. i already have fantastic speed on my second floor... i'm just looking to improve my other floors..
any input much appreciated.
