AidanWebb
Sep 13, 2018Initiate
Netflix & LG TV not working with Nighthawk r7000 (FIXED!)
My R7000p is connected to a DM200 modem (in modem only mode), everything works perfectly except Netflix and some other apps on my LG Smart TV completely failed to load.
I found that changing the MTU setting from 1492 to 1400 completely solved the issue. :)
I hope this helps someone else
SOLVED. See above
1 Reply
- AidanWebbInitiate
SOLVED. See above
