ironchuck
Jan 28, 2017Aspirant
Netflix gives me "unblocker or proxy" error
Until a couple of days ago, everything was working fine. Today I still have internet connection but Netflix doesn't work because it says I'm using unblocker or proxy, which I am NOT. Everything in th...
- Jan 28, 2017Ok so after two days of trying everything I finally came to a "solution" which was to reconfigure my router as an access point. I figured that if the modem/gateway had no trouble streaming Netflix, the fix was sort of turning the Netgear router into nothing more than a broadcast station. Anyway, everything seems to be working in good order now.
Jan 28, 2017Guru - Experienced User
Perhaps try a factory reset of the router, and reconfigure it.
